Can simple oil change replace service C?
Old Sep 8, 2010 | 08:32 AM
todesto's Avatar
Question Can simple oil change replace service C?
Hi, all
Just as titles.
Is service C necessary? What is it?
My car is out of warranty but I own it.
Can I just have the dealer to do oil change only? Would that be good enough?
If I knew how to reset the service indicator, I would go to local shop to do oil change, but don't have information on it so I go back to the dealer.
Any suggestions? Thanks in advance.
Old Sep 8, 2010 | 09:14 PM
waybomb's Avatar
Have C done at an independent instead of the stealer. The price will be much more reasonable.
Old Sep 10, 2010 | 10:55 AM
benz911's Avatar
Here's the detail service for C that i found online. It is mostly inspection items that you have to go through, which i think an average person can do.
Service C:
  • Reset maintenance counter in intrument cluster.
  • Inspect dust filter. Function check.
  • Warning/indicator lamps, illumination and interior lighting.
  • Windshield wipers, rear window wiper, windshield/rear window washer.
  • Headlamp cleaning system.
  • Check seat belts for damage and proper function.
  • Check parking brake [function test only]
  • A/C drain flush
Wheels, Brakes
  • Check front brake pads for lining thickness (remove 1 front wheel).
  • Check condition of brake discs front/rear.
  • Inspect tires for damage and condition.
  • Measure and record tread depth.
  • Correct tire inflation pressure.
Underside of Vehicle
  • Leakage - Major components. Check for chafe marks, line routing, damaged components.
  • Check condition of front axle ball joints and rubber boots.
  • Check condition of steering's mechanical components and rubber boots.
Engine Compartment
  • Engine oil and filter change.
  • Check condition of poly-V-Belt.
  • Check catch, safety catch and highnes of engine hood for proper operation.
  • Check and correct fluid level.
  • Engine cooling system, antifreeze and corrosion protection.
  • Brake system.
  • Power steering.
  • Windshield washer system.
  • Battery: check condition using "Midtronics MCR 717" Tester.
jlulu
Nov 17, 2014 09:25 PM
300DJD
Feb 26, 2006 01:54 AM
fay3131
Sep 21, 2005 03:49 PM
fay3131
Sep 20, 2005 01:39 AM
Jinxie
Apr 4, 2005 03:03 AM
