A/C problem!! help on vents.
Old Nov 5, 2005 | 05:03 AM
edl100's Avatar
Default A/C problem!! help on vents.
I have a 1996 w210 with an aircon pushbutton switch or an Automatic aircon.
When I turn on the aircon, the blower and compressor works fine blowing in cold air from the center vent and right and left vents.
My problem is, without pressing anything on the Aircon switches, the Aircon shuts down the blower air from the center vents and goes into defogger mode by itself!! This means cold air from the right and left vents and the vents above the dashboard for the windshields!!
Hmm,. what is wrong with it? the switch??
Anyway, the aircon goes back to normal sometimes when I shut the aircon off or press recirculate button.
I hope this is not an expensive problem.
Thanks for any help.
Old Nov 5, 2005 | 10:38 AM
phillaf's Avatar
Default RE: A/C problem!! help on vents.
I would look for a vacuum leak.
Phil
Old Nov 5, 2005 | 01:05 PM
Kajtek1's Avatar
I have 99 model I after studying the manual, have learned that the system determinate on its own where to put the air in certain situations and temperatures. The only thing the driver can force out of it is defrost mode, or switching to manual.
I just hate cars, that trying to be smarter, that I am.
Old Nov 13, 2005 | 02:11 AM
touring's Avatar
Might want to check out this guy's solution:https://mercedesforum.com/m_25536/tm.htm. Sounds a lot like your problem.
Old Nov 14, 2005 | 07:25 AM
edl100's Avatar
Thanks.
As of now, the A/C vents are working properly although I haven't done anything yet.
I also noticed a whole colony of ants lived inside the car. I discovered them inside the sunroof mechanisms and some on the dashboard!! I think they might be doing something to the A/C switch. grrrrrr.
Old Oct 29, 2007 | 12:05 PM
edwinburog's Avatar
i have 190e model 1993. aircon continue running even switch off.please somebody help me what i will do
jdmitrturbo
Jan 28, 2010 03:45 PM
grizzly_b
Jul 15, 2009 01:28 AM
desithrilla
Oct 20, 2007 04:53 PM
gruber300
Mar 27, 2007 05:29 PM
edl100
Jan 16, 2006 03:08 AM
