Auto Transmission Fluid and Filter Change
Old Dec 1, 2004 | 01:25 AM
handyjay's Avatar
Default Auto Transmission Fluid and Filter Change
I am ready to change my AT fluid and filter. Any special issues, other than extreme cleaniness, that i need to be aware of? Thanks.
Old Dec 1, 2004 | 01:51 AM
sleepwalker's Avatar
Default RE: Auto Transmission Fluid and Filter Change
drain the torque converter too and replace the ATF filter.
Old Dec 1, 2004 | 10:20 AM
handyjay's Avatar
I know where the drain is for the transmission, but not the torque converter. I assume I remove a cover plate and rotate the converter to a drain plug. Does it fill when I start the engine and put it in gear? Thanks
Old Dec 1, 2004 | 11:56 AM
yes, it fills itself easily.
remove the cover, turn the torque converter and you will see the drain plug.
Old Dec 12, 2004 | 10:51 PM
Buck's Avatar
I paid to have my flid and filter changed about 30K miles ago, I would like to do this one myself. Would it be ok just to change the fluid and not the filter at this time?
Old Dec 13, 2004 | 06:11 AM
on transmission, yes. but on engine, always change the filter too.
parasuco
Mar 13, 2009 02:21 PM
mrcoyote
Jan 18, 2008 02:56 AM
dralle
Feb 6, 2007 01:39 PM
rmt6668
May 9, 2006 03:57 AM
