Is this Auto Transmission Fluid Tank?
Old May 8, 2006 | 05:50 AM
rmt6668's Avatar
Default Is this Auto Transmission Fluid Tank?
I have taken a pic, like to know is this the AT tank? It has the small black top.
[IMG]local://upfiles/10129/E648C29DC21849B0AF1D74E4C858AB56.jpg[/IMG]
[IMG]local://upfiles/10129/61390EA35D7B4D9B893CA2F6E001BAA1.jpg[/IMG]
Old May 8, 2006 | 06:01 AM
BoominBenz's Avatar
Default RE: Is this Auto Transmission Fluid Tank?
That is for power steering. The AT fluid is stored in the transmission pan and the tranny/torque converter itself
Old May 8, 2006 | 06:15 AM
rmt6668's Avatar
Where exactly is the AT Fluid store?
Do you have a pic or schematic?
Mu power steering fluid is low, below minimum, what fluid do I top up with?
Old May 8, 2006 | 07:17 AM
sleepwalker's Avatar
the A/T ATF is probably stored on the A/T oil pan as what BoominBenz says.
i have attached the pic. nothing much to see on it. just a pan similar to a pan. this pan is attached to the lowest point of transmission.
the tank with a small black top is for power steering fluid.
the power steering fluid is MB steering gear oil with part number: A000 989 88 03
if you can't find it, use: Mobil ATF D
[IMG]local://upfiles/1/3CFF5743BFFE4C7C9DEC2B577263ECF1.jpg[/IMG]
Old May 9, 2006 | 03:57 AM
rmt6668's Avatar
How to measure & top up the auto transmission fluid?
Whats the fluid both OEM & compatible fluid?
Kind Regards
Steve's
Apr 4, 2012 05:59 PM
Dobschcan
Jun 4, 2011 07:30 AM
liquid_drop
Aug 8, 2007 04:19 AM
scooby72
Apr 28, 2005 05:36 PM
handyjay
Dec 13, 2004 06:11 AM
