Antifreeze Warning, question
Old Oct 21, 2010 | 05:04 PM
handyjay's Avatar
Default Antifreeze Warning, question
I had an independent dealer/shop tell me that the Mercedes antifreeze was a problem with head gasket leaks. He told me to replace ASAP the factory antifreeze for a domestic brand. Has anyone heard this before? While the E320's have had problems with head gaskets I have need heard that the factory antifreeze could be the problem.
Old Oct 21, 2010 | 05:07 PM
chassis221's Avatar
depends on the year. 96 and newer have no problems with the 112 engines. if you have a straight 6 cylinder 95 and later E320 then yes they do have headgasket issues.
Old Oct 21, 2010 | 05:14 PM
handyjay's Avatar
I am looking at a 1995. So is the factory coolant a problem and should it be replaced?
Old Oct 21, 2010 | 05:21 PM
chassis221's Avatar
I never heard of such a thing . But yeah your 95 will have the inline 6 and they usually have headgasket leak at the back of the engine ....passenger side and the front lipseal..
Old Oct 21, 2010 | 05:27 PM
chassis221's Avatar
Bad engine wire harness too.
Old Oct 21, 2010 | 05:29 PM
handyjay's Avatar
I have not heard that either. I have a 91 300E and have replaced the head gasket for the oil leak in spot you mentioned. Need to do it again. Seems it only lasted about 50,000 miles.
Looking at a low mile 320 and planning that down the road the gasket and engine wiring harness will need replacing. Anything else that is problematic for the 95's?
Old Oct 21, 2010 | 05:46 PM
chassis221's Avatar
a great car actually. some stupid stuff with vacuum and slight rough idle and hesitations from a stop but a great car and engine otherwise.
Old Oct 21, 2010 | 06:12 PM
handyjay's Avatar
Thanks for your comments. At least this car is old enough that I can still do some of the maintenance and repairs. The newer cars are out of my league with all the electronics, etc. My BMW is a "do not touch me" vehicle.
namiejr
Sep 12, 2008 07:42 AM
slantis420
Jul 24, 2007 10:54 AM
grandmax
May 22, 2007 10:10 PM
cigarman
May 21, 2006 01:14 PM
CCCP
Mar 7, 2005 08:35 PM
