air filter
RE: air filter
You just unclip the metal clasps and then unscrew the bolts on the top then remove the hose which is easy to do the filter just drops in. Im sure autozone would be able to supply you with a goodfilter I got the K+N last time and it does seem to breathe better although more expensive.
RE: air filter
just remember, next to changing your oil and oil filter, replacing your Mercedes benz air filter and fuel filter on a regular basis is the single most important act of maintenance you can perform for your engine. do it, and your engine will thank you by giving you many thousands of trouble-free mile.
StickyBenz
02-01-2012 06:24 PM
BlueML320
10-22-2006 04:02 AM
