ABS ESP BAS Malfunction fix
hello raylee brake dust can not affect brake switch cause it's located above brake pedal under dash, you must be referring to brake sensor mounted on each brake roter area...note i had same problem two weeks ago all I did was disconnect ABS wire harness from ABS hydraulic solenoid and reconnect apparently bad connection was my problem.ps look into that simple fix...
