1992 300E cold start, delayed up shift, delayed down shift problems
My 92 with about 50,000 miles started experiencing cold start problem. I replaced the 4 pin coolant temperature sensor and at the same time noticed that the electric connection to the "Upshift Relay Switchover Valve" was not plugged in. Pugged it in. Engine started much better, but still stumbled a bit on idle for a minute or so. Now the tranny would not upshift for serval blocks of driving in 1st gear. At first I thought the new temperature switch was controlling the up shift. Also experienced a problem with the kick down to accelerate. Today I unplugged the URSV and shifting returned to normal. Both upshift and kick down. I tested the URSV the solenoid clicks with power and the valve ports change connection with the power, so I believe the valve is OK. Am I causing some other problem by not having the valve connected? I bought this 300 with 34,000 miles two years ago. It was always serviced on a regular basis at an indy shop. I assume the shop had disconnected the valve. Any thoughts or am I just concerned about nothing?
crusier888
Oct 13, 2019 04:46 PM
mbzachs
Mar 17, 2009 09:33 AM
MARIODRIVE
Nov 21, 2008 05:20 PM
redrabbit
Sep 16, 2005 01:53 AM
