'97 E420 Transmission Fluid Change
I just spent a while reading through previous posts and DIY type info on changing the fluid in my W210. I found a ton of great info but still have a couple questions.
1. Where do I go to buy the correct MB fluid? There is so much emphasis put on using the original MB spec fluid that I want to be sure not to mess this up.
2. I understand from my research that my torque converter will have a drain plug which is great news for me. The trans pan will also have its own plug. Where do I put the new fluid? Is there a fill spot on the transmission? Also, do I put in a couple quarts at a time and then run the car to get the fluid in the TC? Does it need to be in gear to do this?
3. What parts do I need to complete this DIY? Fluid and filter? Is there a pan gasket that needs replaced?
Any help is much appreciated!
Thanks,
Brandon
Thanks,
Brandon
I have a 2000 E320 & I have change my tranny fluid twice already. MB ATF, filter & gasket from Autohausaz.com. You will need a special dipstck to measure the fluid. You can also get them from other on line retailers.
97, 97e420, benz, change, diy, e420, fluid, information, level, mercedes, oil, trans, transmions, transmision, transmission, trasmission
