97 E420 RPM surging
Old Jan 17, 2006 | 10:54 PM
thequif's Avatar
Default 97 E420 RPM surging
I have a 97 E420 and the engine rpm is surging at idle from about 500 to 1000 rpm up and down, in cold weather only. When the weather warms up a little it stops.Any ideas would be great. It starts happening at about 5 degrees.
Old Jan 28, 2006 | 07:32 PM
vytamenc's Avatar
Default RE: 97 E420 RPM surging
thy this you have whats called a purge on the left hand side of the engine compartment neer the washer fluid bottle its a little black valve there are two hoses running to it on is vacuum all the time one goes to your charcole canister. what i want you to do is when it is surging i want you to apply the parking break leave car in drive and disconnect the vacuum hose to this valve plug it with your finer does the surging go away if so replaced your purge valve (i call them a surge valve for this reason)
Old Feb 1, 2006 | 12:26 AM
thequif's Avatar
OK I will try that
revrunt
Nov 11, 2008 09:17 AM
trish08
Jun 17, 2008 03:47 PM
thequif
Jan 17, 2006 11:23 PM
thequif
Dec 1, 2005 01:48 AM
hendy
Nov 26, 2004 01:25 PM
