97 e420 fault codes - stalled , won't start
Old Jul 5, 2007 | 10:12 PM
kmulholl's Avatar
Default 97 e420 fault codes - stalled , won't start
alright, car dies on the highway, towed home, sits 3 days, finally pull the codes (7 of them), cyl 2 + 4 misfire, cam pos sensor , coolant temp, idle air control, and both side 02 sensors. anyone think theres a common thread- please HELP ! engine seems to crank normally, just not firing.
Old Jul 6, 2007 | 02:44 AM
snanceki's Avatar
Default RE: 97 e420 fault codes - stalled , won't start
Problem is which of the codes are "live" and which are historical.
Sure you have a spark and fuel?
Since engine won't start try a new CPS Crank Position Sensor (not too expensive).
Not sure if your Cam PS is an alternative to Crank PS.
Crank PS doesn't usually generate a code when it goes bad just stops the car starting since the engine doesn't know when to fire.
Clear codes and see what returns...and what doesn't.
60% CPS will correct matters.
O2 sensors shouldn't impact starting.
Stuart.
Old Jul 6, 2007 | 09:54 AM
kmulholl's Avatar
stuart, thanks for the info - the only "new" code is for cyl 4 misfire. the others are considered "pending" by the code reader manufacturer (actron). also ,if i clear the codes , will new ones show even though i can't start the car?, it only cranks . one more thing, where's the cam pos sensor - i didn't recieve my repair manal yet - i ordered it the night i broke down - thanks , kmulholl - jerry
Old Jul 6, 2007 | 11:33 PM
snanceki's Avatar
So since you cleared the codes nothing has come back. OK. No problem.
CanPS. Location?
Front of the cam cover (I would guess), Little black plastic thing with wires.
Stuart
CLK503
Dec 3, 2011 09:20 AM
todesto
Jan 24, 2010 07:21 PM
dougted
Aug 10, 2009 01:39 PM
bennzs500
Sep 6, 2007 02:01 AM
michaeld
Oct 8, 2005 10:32 PM
