2005 E500 4matic PSE Pump
There is indeed a PSE pump. It is located in the trunk on the driver's side and adjacent to the rear lamp. The problem is that my lumbar supports will inflate for about 30 minutes and then deflate. If I turn the ignition off and then restart the car, the bladders will inflate for another 30 minutes or so. The door locks and trunk release which are also dependent on this pump don't have an issue. I have inspected the lines and fittings at the pump and in the seats and there does not appear to be an obvious leak. So, I am wondering if the overpressure valve that may malfunctioning. If so, does anyone know the PSI provided by the pump and can the valve be replaced?
bgroup
Dec 29, 2009 06:42 PM
