2004 E-320 suspension modification (to accomodate larger wheels)
it is called plus sizing. As long as you keep the et (offset) close to stock and don't try slipping a lot wider rubber into the wheel wells you are fine. www.tirerack.com and www.discounttire.com both have tire rim calculators.
If you lower it is when you need to consider suspension contact issues and modifications.Non 4matic you can fit up to a 275 wide rear and a 235 front with no issues if you have the proper offsets to run staggered set up.
Measure twice,install once
dimitristx
Nov 2, 2014 11:51 AM
2004, 320, install, larger, mercedes, modification, modifications, modified, online, rims, run, suspension, wheels
