2001 Mercedes E430 sometimes starts sometimes doesn't
Old Jan 21, 2011 | 05:34 PM
walpoleauto's Avatar
Default 2001 Mercedes E430 sometimes starts sometimes doesn't
I have a 2001 Mercedes E430 4matic and I am running into an issue where if I put the key in to the ignition, sometimes the car will start, sometimes it won't. When I run into the issue of it not starting, I leave it alone for about 30 minutes and then I come attempt to start it again. It is not a battery issue, there is plenty of power. Help.
Old Jan 21, 2011 | 08:17 PM
waybomb's Avatar
Not starting, meaning it cranks for about 15 seconds and then stops cranking? When the engine has warmed up on a prior trip? If yes to both then - Crank Position Sensor. Located at the back of the engine, inserted in a while above the flywheel, held in by a torx fastener.
Chill E
Aug 18, 2009 06:29 PM
hughits
May 19, 2008 12:26 PM
widmer
Oct 19, 2007 03:14 PM
bookerzisme
Jan 12, 2006 08:43 PM
nkosi
Jun 12, 2005 10:45 PM
