2001 E320 Transmission Problem
Old 08-12-2020, 09:26 PM
sboakye's Avatar
Default 2001 E320 Transmission Problem
I have 2001 E320 and the car started driving on just the 1st gear, no up-shift so these are the steps I have to perform to try to correct the problem:
  1. Change the conductor plate - Result: Still, the car cannot shift.
  2. Replaced the transmission - Result: Still, the car cannot shift.
  3. Replaced the Shifter - The problem still remains.
The question is: What could be the problem?
Old 05-11-2021, 08:11 PM
mcguirejw's Avatar
If this is a W210 like my 1999 the transmission is connected to a module atop the right fender/wheel you can see when the hood is open. The connecting cable carries transmission fluid and an electric wire, inside the connector I believe. Why it was designed this way? No idea. I think this module is pretty critical to proper transmission shifting.
2000 SLK230
07-22-2013 09:26 PM
topsyjoe
07-14-2010 03:31 AM
sal911
12-10-2009 12:16 AM
boywonder
07-18-2006 10:41 PM
ddipaolo
03-25-2005 08:21 PM
Quick Reply: 2001 E320 Transmission Problem
