2000 ml320 transmission issue
Old Apr 13, 2012 | 01:29 PM
vladimirhaoui's Avatar
Default 2000 ml320 transmission issue
I bought this ML320 in an auction and soon after I start driving it; the transmission start to slip and sometimes does not change after the car is driving for about 30 minutes; it drives fine and normal when the car is cold. I took it to the dealer and they told me there is an alarm that is coming out that says "Transmission Control System Failure". they suggested to change the transmission. As you can see; that is not the answer I was expecting because it is not making sense to me. I think it sound like a sensor or something electricly. Anyone can suggest what to do would be greatly appreciated. Thank you
Old Apr 13, 2012 | 03:57 PM
chassis221's Avatar
make sure fluid level is good first...then next step is to check the trans control unit for trans fluid that has worked its way into the trans control unit via the wire harness.
then also could be the transmission conductor plate, which is very common but will usually throw speed sensor fault codes.
CJPatel
May 29, 2013 01:41 AM
SacML
Sep 28, 2010 05:03 PM
axm1955
Sep 13, 2007 10:07 PM
patrickls7
Jul 22, 2006 01:21 PM
oysterbenz
Oct 9, 2005 11:05 AM
