1998 E320 Electrical Problem
Old Apr 14, 2009 | 11:32 AM
muchomanos's Avatar
Default 1998 E320 Electrical Problem
Started with driver's window failure, progressed to power seat
Then "healed"
Spread to Passengers, interior lights, rear-view mirrors, steering wheel, sunroof
Only rear windows continue to work
Is there a common module that controls these devices?
Old Mar 28, 2011 | 08:29 PM
Tasma's Avatar
Angry I'm having the same problem
I have the same problem with my 1999 E300.
I I disconnect the battery and wait a few seconds then reconnect everything works again for a while. They usually fail again right after I start the car and not while it's being driven. Sometimes it's both widows, sometimes one window and mirrors.
I just did new fuel lines and conductor plate in the transmission...getting tired of working on the car
Old Apr 4, 2011 | 01:03 AM
raymond~'s Avatar
hunch....i'd seriously give the fuse cluster, PSE pump (both under rear seat) a super close
inspection. this almost sounds like classic case where water intrusion occurred and has
caused electrical disruption to one/both devices mentioned.
cause could be a plugged drain, causing water to accumulate in that compartment
the foam and plastic surrounding the PSE module may cause water to be retained longer
darvish
Mar 2, 2008 08:07 PM
BenzoDJ
Jul 10, 2007 10:09 PM
DRPruitt
Jun 26, 2006 03:38 AM
mwfcpa
Oct 24, 2005 04:21 PM
