1991 300e 24 valve hesitant on acceleration
My car has hesitant acceleration on take off from standstill. I have changed the injectors, leads, s/plugs which has improved it but not eliminated the problem. It also becomes worse after "heat soak" of the engine. However, there is no problem before the engine warms up fully. Please help...I wonder if its an electrical problem of some sort. Thanks
![Smile](https://mercedesforum.com/forum/images/smilies/smile.gif)
This is a DIY for transmission mount replacement on a W210, but it is similar to yours.
http://www.benzworld.org/forums/w210...placement.html
Consider searching/asking in this forum, you should be able to find the answer.
http://www.benzworld.org/forums/w124-e-ce-d-td-class/
Hi. I had it adjusted some time ago. apparently the car was running slightly rich. Fuel-air ratio was adj the proper way and car drives really well now. Could have saved me some $ if I had known this!!
