190E - Burning Oil first 10 mins
Old Jan 5, 2004 | 08:31 AM
gtoofany's Avatar
Default 190E - Burning Oil first 10 mins
Hi,</P>
Recently my 190E has been burning what smells and looks like oil for the first 10 minutes or so. I have heard this could be due to the washers being broken or worn, resulting in oil slowly leaking into the cylinders.</P>
Is this an expensive problem to fix, or should I think about getting shot of it?</P>
Thanks,</P>
</P>
Old Jan 5, 2004 | 04:03 PM
jetforeman's Avatar
My guess is that your referring to the valve guide seals (washers?) And yes that will cause some smoke on start-up. Not sure how much it would be in the UK to get this fixed....
Old Jan 6, 2004 | 11:30 AM
jocor's Avatar
The seals themselves cost about £20 a set from isaac agnew mercedes benz dealership. To fit them it can be done without removing the head it could cost £50-£100 depending on the mechanic! I also got the cyl head valves grinded in and the valve guides replaced with titanium ones. This has stopped the before minimal oil consumption the car had. I would recomend that you buy a haynes manual and do it yourself. All this work costs about £200 in head maching and parts. If you want more info just reply!
mike.stephens2
Mar 14, 2011 02:19 PM
ahedels
Oct 16, 2008 05:58 PM
BCinPhx
Oct 23, 2007 10:44 AM
zofitness
Jul 9, 2007 02:18 AM
srogers312
Jul 24, 2006 03:31 PM
