Weird issues with 2006 CLK turn signals??!!
Old Oct 20, 2009 | 02:27 PM
Clkboi's Avatar
Default Weird issues with 2006 CLK turn signals??!!
Here is my problem:
When i turn the left signal ( driver side) my high beam (left) turns on as well.
I thought my orange turn lights were gone bad so the car is using the high-beams as a backup. I go and check and its working fine.
I get an error once in a while on the OBC telling me the bulb is out ( orange one)
Wen to the dealer today and they said it works fine but my aftermarket HID's or the aftermarket LED's i have on might trigger it to go on.
I think that is totally bull and they are saying it is just becuase they couldn't figure it out.
Anyone else had an issue with this? Will changing the bulb fix this problem? I went ti Sylvania and it says i need 1157A but the one i am currently using is a 1156.
Any input would be appreciated as i am blinding people on the street at night.
Update: I just bought a new bulb and changed it. Problem still exists.
I really do need help now....
Old Oct 20, 2009 | 05:46 PM
chassis221's Avatar
first make sure the bulb is the same as the one that is working correctly on the right side. it is possible maybe that the HID lights were wired incorrectly. but i guess everything worrked ok at one time? if you have the wrong bulb all kinds of weird stuff can happen. make sure you take a close look at the pins on the bulbs. again compare to the right side bulb that is working correct.
Old Oct 20, 2009 | 10:24 PM
Clkboi's Avatar
I will definitely do that tomorrow see if there is a difference.
And yes everything was working ok for like 5 months after i installed my HID's and i have no clue of why this might have happened.
Appreciate your response i will do as you say tomorrow.
Thanx
deegoode
Feb 1, 2018 03:34 PM
redtees1
Jun 20, 2011 03:13 AM
FreddyMerc
May 9, 2007 09:04 PM
andrewgclifford
Jan 23, 2005 11:56 PM
steffen_fox
Aug 4, 2004 07:22 PM
