Door control module
Door control module
hi all,
i have a 2001 320 clk convertible, noticed my passengers memory mirror didint work and passengers side window didnt drop when you open the door - took the trim off to find the door control module is from a w210 e class??? have purchased tyhe correct module and fitted but now the window drops about 2 inches??? have tried resetting the windows too??
what am i doing wrong ?? i assume there is a set way to change the door control module and i must just be doing it wrong
RE: Door control module
what was the part number and VIN? we can check the correctness of parts.
the control module must be first desynchronized and resynchronized to get it work properly.
there is a hall sensor which count the position and this can be corrected during adaptation.
hi all,
still having no joy, anyone know how i desync the old unit thenre sync the new one?
another thing worth mentioning is... my passengers side mirror up and down options seem backwards??? if i press the up control the mirror goes doen and vice versa? and the passengers mirror does not auto dip?
could all this be related to the module? if so any help tp desync and reync the new one would be great
the part number is correct if for the front left door.
you will need a star diagnosis computer to resynchronize it.
however, you can try by removing the battery terminal for two minutes and touch the two terminals together momentarily to purge the remaining current (WITH BATTERY ALREADY ISOLATED!).
reconnect and initialize the power window by lowering it down completely while keeping the switch pushed for 3 seconds. then raise the window up completely and keep on pressing the switch for another 3 seconds even after it is completely closed. close the doors fully while doing this.
Thanks will have a go this weekend - could this also explain why one of my memeory mirrors does not work and wwhy the same mirror moves up when i press the down control and down when i press the up control?
many thanks for your help
donjuan45i
03-09-2008 10:42 PM
NMB
07-14-2004 01:32 AM
