Clk500 722.9 transmission bellhousing bolt's torque specs?
Old Mar 26, 2022 | 12:41 AM
Sliding E500's Avatar
Default Clk500 722.9 transmission bellhousing bolt's torque specs?
Hello, MercedesForum.
I have a 2005 clk500 unfortunately its leaking from the front of the transmission bellhousing. I believe front transmission seal poped out therefore causing all my transmission to leek all the ATF oil. I'm thinking it might be the transmission oil pump seal that also goes bad. Either way I'm installing new seals since i will have it open at this point. I'm informed of how to remove transmission but I need help with the transmission bellhousing bolt's torque specs and the torque converter bolt's torque specs. I don't want to overtight & brake the bolts by guessing the torque specs. Any information on the torque specs to re install a 722.9 transmission (7g tronic) would be highly appreciated.
dablade
Jun 19, 2017 02:43 PM
zdzich
May 15, 2011 09:52 AM
jlguler
Sep 23, 2009 08:34 PM
barrylndn
Mar 3, 2009 08:07 PM
gotta6.9
Oct 29, 2006 05:35 AM
