OM 617 Flywheel Bolts
Old Sep 19, 2009 | 10:48 PM
jlguler's Avatar
Default OM 617 Flywheel Bolts
Hello,
I have an OM617 with the flywheel removed. Can I reuse the original bolts?
Regards,
John
Old Sep 23, 2009 | 05:20 PM
jlguler's Avatar
Default Flywheel
I found another flywheel for an OM617. My intention was to drill four holes in it to match the torque converter pattern of the Jeep. Are they interchangeable from engine to engine? I have read conflicting opinions of this, wondered what you guys thought.
Regards,
John
Old Sep 23, 2009 | 08:34 PM
jlguler's Avatar
Default Torque Converter
I am going to try and find a machine shop that can weld the Benz style tabs to the Chrysler converter. Then I can reuse the stock Benz flywheel and flexplate. I marked the position of the flywheel and the crank before I took them apart. The two converters are close in diameter. The flywheel to crank bolts will clear the Chrysler TC. I would run the Benz trans, but then I would have to have a custom driveshaft made and lose the four wheel drive.
Thanks for your input,
John
enovey
Mar 4, 2008 07:47 AM
MasterWangg
Oct 25, 2006 11:18 AM
jdogsarman
Jul 29, 2006 12:50 AM
Kermit
Jun 22, 2005 04:15 AM
stef22
May 18, 2005 12:07 AM
