2000 CLK Standard Radio won't take code...
Old Jan 25, 2007 | 05:57 PM
coolhand's Avatar
Default 2000 CLK Standard Radio won't take code...
Just bought this used...A new battery was put in and the radio won't even power on, not to mention accepting the code...Checked that the fuse is good...Please help! Thanks! Ben[:@]
Old Jan 25, 2007 | 10:52 PM
Benzel's Avatar
Default RE: 2000 CLK Standard Radio won't take code...
try pulling the fuse out and putting it back in, could be a bad connection... maybe.
Old Jan 26, 2007 | 12:28 AM
coolhand's Avatar
Thanks, Benzel! Checked the fuse and it's good. I wonder if the radio is totally dead, or can still be reprogrammed.
Old Jan 30, 2007 | 01:19 AM
sethworm's Avatar
You can call Mercedes 1-800 and they will have your code on file. You could check to make sure the code card is correct.
Just a thought
Seth
Old Feb 2, 2007 | 03:16 PM
coolhand's Avatar
Thanks for the tip...I took the car to a small shop in Santa Monica and had the radio swapped out. Cost me $350.00. The radio powered on, so my guess is that the display is bad, and should be an easy fix. The MB dealer quote was well over $1k.
Old Mar 9, 2007 | 09:30 PM
wildoutfilms's Avatar
a
briand2001
Aug 7, 2010 10:12 AM
audi_driver
May 22, 2006 08:33 PM
zexx
Dec 21, 2005 12:19 AM
C230 Sport Sedann
Apr 19, 2005 04:46 PM
cisco
Apr 12, 2004 05:50 AM
