Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
Head bolts on Cl600 torque specs and sequence
Old Nov 1, 2008 | 04:36 PM
cl600guy's Avatar
Default Head bolts on Cl600 torque specs and sequence
As many of you already know. the Cl600 has a bad seal inside the oil cooler assembly thyat goes on top of the engine and under the heads. Took it off and to my suprise that gasket was not sold seperetly. Had to get a whole new oild cooler assembly. anyways got the heads and chain back on, now i need to torque my heads back on. Does anyone know what the torque specs and sequence is for the cl600 head bolts? called mercedes and they were just not to helpful. They said that there isnt any. LOL.
So i turn to you my cl friends. if you have any information. please respond
thank yuo
Old Nov 3, 2008 | 10:54 PM
phamilton's Avatar
Default RE: Head bolts on Cl600 torque specs and sequence
Tighten cylinder head bolts in stages in the order of the tightening diagram.
1st tightening stage55 Nm .
2nd tightening stage 90° tightening angle.
3rd tightening stage 90° tightening angle
If you need anything else for this car let me know, do you have the timing procedure for the car? I just replaced everything from the head gaskets up in my cl 600, remember the head bolts are torque to yield so they really should be replaced. I know people that have not replaced them and didnt have a problem,but if they are streched you should replace them......fyi hope that helps.
Old Nov 3, 2008 | 10:56 PM
phamilton's Avatar
Old Nov 3, 2008 | 11:03 PM
phamilton's Avatar
I had a hard time uploading, sorry.....
[IMG]local://upfiles/33375/C6922A45FD1D41E5B866475B82F00C8E.gif[/IMG]
[IMG]local://upfiles/33375/158A639C31174062A685E2B82F00F83B.gif[/IMG]
stevenlee34983
Jan 21, 2010 07:58 PM
mikehummer69
Jan 11, 2009 11:05 PM
rolandk
Mercedes A Class
May 28, 2007 08:45 AM
wilbur1
Apr 16, 2006 01:00 AM
