Windshield Wiper motor problem
Old Apr 16, 2009 | 08:54 PM
Johnny Mac's Avatar
Default Windshield Wiper motor problem
I have a '94 C220, and when I turn the windshield wipers off they do not return to the original resting position, they come to rest at various points across the windshield. I have replaced the fuses, but no luck, also the intermittent feature only takes the blades to one side of the windshield and stops and then rests and then returns them to about 3/4 of the way back as so forth... Any ideas what might be causing this?
Old Apr 17, 2009 | 10:55 AM
platonmind's Avatar
1. Cable or cable connections loose, broken or disconnected,
2. Faulty relay,
3. Faulty wiper motor.
Old Apr 18, 2009 | 06:33 AM
Johnny Mac's Avatar
Plantonmid, thank you for replying... because it is an intermittent problem, I am thinking that it could be the relay, where is that located? Is it next to or in the wiper assembly housing? Also my cruise control feature works sporadically as well, could that be tied into the same electrical tier?
Old Apr 18, 2009 | 10:55 AM
chassis221's Avatar
lube the wiper arm shock/shaft that moves in and out. they dry upand need lube. there is a cover that will pop off at the bottom of the arm and you will be able to see the piston/shaft that moves put some antiseize on it and if that doesnt fix it then you will need a motor or a new wiper transmission or gearing.
Jim Cahoe
May 3, 2009 11:41 AM
alruff
Nov 9, 2007 04:46 PM
gus_carrero
Jul 16, 2007 10:22 AM
Zippy50
Sep 11, 2006 07:09 PM
sokhoms
Jan 29, 2005 02:59 AM
