windscreen washer problem
Old 11-18-2005, 09:49 AM
stinger's Avatar
Default windscreen washer problem
hi guys anyone help me ive got an intermittent fault with my washers the pump is working ok but one time one jet will work then another time the other jet will work then none at all anyone come across this problem before ive looked at the little 2 in 1 little white gizmo which splits the two pipes to each jet its clean and not blocked its got a little piece of rubber tubinbg around it which is supposed to be there i guess and when that is off i press the washer button and both tubes are sprying out water please can someone help
Old 11-18-2005, 12:15 PM
Default RE: windscreen washer problem
Take a thin wire like the wire that is used th close a baggie (strip the paper off) and push it throu the holes where the water cones out to see if a little piece of dried washer solvent is clocing it. or ger a can of computer parts dust off spray and blow the holes out.
owenrich
04-19-2009 07:58 AM
paulwith
01-24-2009 10:53 AM
zoom480
11-12-2008 10:46 PM
denverbres
02-16-2008 09:15 AM
horseybird
10-27-2007 02:12 PM
Quick Reply: windscreen washer problem
