W202 Transmission Fluid
My next project is to flush the tranny fluid on my 99 280.
We all now know for the fact that -- other than longevity, synthetic engine oil and dyno oil perform more or less the same; and that neither will ruin the engine.
How about the tranny fluid? Do I really have to put expensive Mercedes Benz fluid, or any good brand will do? (Say I promise to flush every 50k.)
Also...is flushing tranny fluid difficult and has some tricks? Or is it as simple as draining the oil out of engine?
About measuring the remaining fluid: can I just stick a chopstick? Or I must buy the thingie from MB?
One last question. How many quarts does my car take for tranny fluid?
RE: W202 Transmission Fluid
When your '99 came out, MB had the only fluid that should be used in the 722.6 transmission. Seven years later, companies like Red Line and BG Products claim to be compatible with the MB A\T Fluid. That said, I'd use the MB product. I recently had my changed with BG Products and the tranny seems louder and doesn't shift as sharply. It is probably OK, but I don't like the performance change. I'm going back to MB.. About the price: Stealership price is $20 litre and you'll need 7-8 litres. However, Importec sells the same product for under $10..
It is possible to change yourself, however, from what I understand, one must follow an explict procedure. Example, oil must be heated to 80 degrees C and fluid level is critical. Here is a DIY plan. But I'm not vouching for it.
From what I've been hearing....now I don't dare to put anything but MB tranny fluid.
But again, I am curious. A transmission fluid is a transmission fluid. If I put a name brand good quality fluid, is there any reason MB tranny would start to fail?
Is MB transmission design really absolutely different from most of the main-stream transmission designs that it demands special fluid?
Still flirting with DIY job. You do have to follow some close instructions, but if you do a search on www.mercedesshop.com you will find several different articles like the one I posted before. I would read as many as you can. I am sure I left some stuff out, and others probably do as well, since we don't do these all day. So if you read several of them you cover all your bases. I cut and pasted several articles and checked them as my dad and I did it. However, if you don't have access to a lift I might just pony up the dough. When you consider the cost for filter and fluid and dipstick top it's not going to be that much extra. Just make triple sure that if your transmission pan does not have a magnet that the shop puts one in the corner of the pan. Most models with the sealed tranny don't have the magnets which is really stupid, so get one. I would only use MB's fluid period.
ontheball247
07-04-2021 11:03 AM
liquid_drop
08-08-2007 05:19 AM
C280
04-19-2007 08:06 AM
