w202 instrument cluster
Old Sep 7, 2006 | 06:17 PM
GERMAN MAD's Avatar
Default w202 instrument cluster
Could someone please help me , i have a lack of illumination on my speedo and wish to change the bulbs i have changed them on my 203 however i can not see how to remove on my 99 c220 .
Old Sep 19, 2006 | 10:29 PM
mb4me's Avatar
Default RE: w202 instrument cluster
You need to pull out the entire cluster. The bulbs are replaced from the rear. You can use the special Mercedes tool to pull the cluster or bend a coat hanger with just a little lip on it to pull it out. If you use the latter method best be careful not to damage the dash surrounding the cluster.
Old Sep 20, 2006 | 03:48 PM
gpagdilao's Avatar
You need a tool that looks like a thick gauge wire with a hook on one end and a handle on the other. You can buy this tool from eBay.
Old Sep 23, 2006 | 07:31 PM
Buli's Avatar
Found this link in another post on the topic:
http://202tech.mkosonen.com/howto/instrument.html
It might help a bit.
Old Oct 12, 2006 | 12:40 AM
mycarlile's Avatar
Be sure to order the bulbs beforehand. They aren't available at autozone. Seems like the dealer wanted $4 each for the little bulbs.
'94 C280
Old Apr 18, 2016 | 11:37 AM
wahand's Avatar
Default W202 Instrument cluster
Hi - can anybody please help me - I wants to know if there is any other clusters that is compatible with cluster part nr. 2025407247
Old Apr 22, 2016 | 10:55 PM
chassis221's Avatar
I have a cluster for an older C class. Maybe 97-99 model year. In perfect shape. I'll have to check the part # .
Roadhugger
May 18, 2018 02:01 AM
jerzstyle00
Apr 22, 2011 10:05 PM
danj111
Oct 16, 2005 01:16 PM
CLK500KID
Oct 29, 2004 12:24 AM
