w202 fuel tank sender problem
Hi everyone
i have a w202 with a constant prolem ie it cuts out , turns out that the scavange pump that keeps the level right in the tank is not functioning correctly , has anyone got a diagram it is a w202 193 estate car , senders are under tank , does anyone know of any common problems , sensors seem to work . We fed tha car from seperate tank as it was empty in car tank , we allowed fuel to go back on the return into other side of car tank. This meant we had two gallons of fuel go up return side , however none coming out of other side of car tank i.e side of fuel filler . Hope you can understand this but also help me with diagram.
Many thanks in anticipation .
