Steering wheel removal
Old May 7, 2006 | 06:41 AM
allanb888's Avatar
Default Steering wheel removal
Regarding my wife's 1995 C180, I suspect that the steering column spiral canester is faulty (Horn and airbag faulty) , and I need to remove the steering wheel.
After removing the airbag, the steering wheel seems to be attached by a nut which is removed by a large allen key. I can't loosen it even using a good quality
allen key socket with a long extension handle. I assume that you can't use the ignition steering wheel lock to stop wheel rotation when loosening the nut, as it will break with the force.
I don't have a workshop manual for the C180, and I want to check that I am on the right track, and haven't left anything out. Could someone please advise.
Old May 7, 2006 | 08:10 AM
sleepwalker's Avatar
Default RE: Steering wheel removal
just unlock the steering wheel and turn it to left stop, and have one person assist to lessen the force.
baracuddda
Jul 4, 2007 08:38 AM
uberwgn
May 6, 2007 02:37 PM
AMGMercedes
Apr 2, 2007 10:49 PM
bikeman
Oct 4, 2006 12:50 PM
Benzaholic
May 14, 2006 11:42 PM
