Starting Problems C280
Old Aug 20, 2005 | 08:45 PM
dan21154's Avatar
Default Starting Problems C280
Hello all, I have a C280 1998. I bought car in Dec 2004 and what a ride so far. Replaced water pump, then was having same problme as now...and replaced the start module or so I think that is what it is called. Now I have just got the car back from a transmission replacement.
Currently when I turn the key I hear either a hum or clicking almost like a bad starter type sound. Sometimes the car starts and then sometimes it does not. Been towed to mechanic about 4 times already...and could sure use some serious help. If anyone has any ideas I would sure appreciate them Thank you for you time.
Old Aug 21, 2005 | 12:17 AM
dondas's Avatar
Default RE: Starting Problems C280
If it is the V6, which judging by the year, it should be, Try lubricating the ring gear with a light smear of grease. Sometimes the pinnion gear on the starter jams as it engages. There is a special grease for this job,which is silver in color, but also, don't over do it as you may end up with grease on your crank sensor
Old Aug 21, 2005 | 02:55 PM
dan21154's Avatar
Hi, tyvm but do not think it is the grease.....already replaced one relay. Today when I got in put key in...and just clicked..then after about 15 seconds it started. Does that sound like grease on the starter??????
If sao that would be easy fix. But not optomistic...car since december 04 car has made me crazy. But I love it so want to get it all fixed. TYVM
Old Aug 21, 2005 | 07:52 PM
dondas's Avatar
Yes it does sound like the ringear needs lubricating. The proper grease is "Optimal paste TA" (08452-215) It is very expensive grease though.
Old Aug 21, 2005 | 10:15 PM
dan21154's Avatar
Ok will give it a shot any idea how to get starter out is it easy or hard?????? and Tthank you very much for the help
Old Aug 22, 2005 | 01:22 AM
dondas's Avatar
The Starter is pretty easy to get out, just make sure you disconnect the battery of course.
Old Aug 24, 2005 | 12:01 PM
dan21154's Avatar
Ok starter lube was not the problem. Starter was removed and lubed and car still same. Turn key and it click or does nothing at all. Engine does not turn....any other information would be welcomed. Thanks.
Old Aug 24, 2005 | 12:22 PM
sleepwalker's Avatar
battery terminals all clean and good contacts?
Old Aug 24, 2005 | 11:19 PM
  #9
Bvanderweide's Avatar
I have had the same problem with my C280. I turn the key and nothing - it just makes a clicking sound. Normally all I have to do is turn the key back to the starting position and remove it. I then put the key back in and she normally fires right up. My dealer said that the issue has to do with the nature of the key. The key is an electrical key and he says that sometimes the "relay" in the key or the sensor in the dash don't register. I'm not very mechnically inclined, so I may have not described this real well. My dealer says sometimes all that's need is a new key; however, a new key will run approximtely $150.
Old Sep 2, 2005 | 06:48 PM
  #10
dan21154's Avatar
Ok all here is the update. New starter installed along with a newutral safety switch above the transmission. Picked up car yesterday and this morning nothing again. No sound no noise. Turn key and nothing.
Is it possible the alarm system has something to do here , just a thought. Thanks.
