SRS light malfuction SOLUTION
Old Nov 4, 2008 | 11:42 AM
thomasmaio's Avatar
Default SRS light malfuction SOLUTION
Hello to all my fello MBr's out there.
Just thought I would share this with you.
Got my SRS light to come on and found that the harness under my passenger seat (it is under the front of the seat red harness) had two brass prongs that plugged into the female end. One of the brass prongs was pushed back into the harness and was not making a connection causing the light to come on. This harness is in a strip under the seat and the strip is held to the seat by to simple phillips screws. Unscrew them and you can work the wire/prong back into the harness.
Cured my problem. Hope this helps someone. Search SRS on the forum and Sleepwalker has pics of where all the sensors are on the system.
cobracop
Mar 11, 2013 09:23 PM
alragins
Jun 19, 2008 06:39 AM
ninobrown19
Nov 15, 2007 11:32 PM
milicev
Aug 11, 2006 02:07 PM
GP
Nov 22, 2004 02:21 AM
