SL TOP MALFUCTION
Old Aug 1, 2006 | 01:07 AM
milicev's Avatar
Default SL TOP MALFUCTION
Hi, I have a 1993 300 SL and the top will not go up or down. It used to go up and down sometimes but not work all of the time. I also noticed that if the antenna goes up the top will not work, if the antenna doesnt go up when i start the car the top works. I dunno if there is any relation or if it is a stupid coincedence. What I'm wondering is if anyone has had problems with this or if anyone can tell me how to check my system out. The rollbar still works so i think the pump is ok. Any diagrams or helpful hints would be greatly appreciated.
Thanks, Danny
Old Aug 1, 2006 | 06:32 PM
milicev's Avatar
Default RE: SL TOP MALFUCTION
Also, does anyone know how to reset the system maybe that would work. Thanks, Danny
Old Aug 2, 2006 | 08:07 AM
stats007's Avatar
The roof ECU can be reset by disconnecting the battery - though make sure you do it carefully with no ancillaries on to prevent spikes etc. You then need to resynchronise the windows and rollbar - this information is in the owners manual - basically you operate each window individually and hold the button down for 5 seconds when fully open and fully closed. You may also need to operate the roof manually - the latches sometimes go out of sync - i.e one open one closed.
Old Aug 3, 2006 | 01:49 PM
bobterry99's Avatar
ORIGINAL: milicev
You can read diagnostic codes on your convertible top system with nothing more than a short length of wire, Danny. Codes are read one at a time. You must have the key in Position 2 for this. To trigger a read, you short socket #10 of your car's diagnostic connector (picture) to socket #1 for 2 to 4 seconds. A second or two after the short is removed, the light in the convertible top switch will begin to flash. Count these flashes and you have a code. Re-trigger another read to get the next code and repeat until you have all of them.
Once you have read all of the codes, you may wish to go back and erase them. They are erased individually one at a time. To do this, read a code, wait a few seconds, and then short the diagnostic socket to ground for 6 to 8 seconds.
There are 30 possible codes. Post back what you find for further help.
[IMG]local://upfiles/4629/0019D8785D124DF5A49D226450A0F5BF.jpg[/IMG]
Old Aug 7, 2006 | 04:49 PM
milicev's Avatar
Hi, thanks for all the help guys. Bobterry your suggestion helped alot. The codes that poped out are as follows:
1 long blink 16 short blinks
1 long blink 17 short blinks
1 long blink 18 short blinks
1 long blink 23 short blinks
1 long blink 28 short blinks
1 long blink 29 short blinks
1 long blink 30 short blinks
Does anyone know where to find what they mean or know what the problem is with my system. Thanks again for the help, Danny
Old Aug 8, 2006 | 12:05 AM
bobterry99's Avatar
With that many codes, some of those must be old. They remain in controller memory even after the condition that caused them is corrected. So, I suggest erasing all of them and then reporting back the ones that return. This is particularly important in your case, because a code 29 is among 3 codes that will prevent the system from operating until it is erased.
If you send me an email I can send you a document that lists the codes.
Old Aug 8, 2006 | 12:27 AM
milicev's Avatar
Hi, Bobterry I believe I just sent an email but not sure so let me know if you didnt get the message. If not my email is milicev2@uiuc.edu. Thanks for all your help, Danny
Old Aug 11, 2006 | 02:07 PM
sbwor's Avatar
Milicev,
The discribed proceedure corrected my top issue earlier this year.
cobracop
Mar 11, 2013 09:23 PM
thomasmaio
Nov 4, 2008 11:42 AM
alragins
Jun 19, 2008 06:39 AM
ninobrown19
Nov 15, 2007 11:32 PM
GP
Nov 22, 2004 02:21 AM
