Service reset
Old Aug 4, 2011 | 12:00 PM
SteveKnight's Avatar
Default Service reset
I am taking my 55 plate 2005 c220 cdi to be serviced but not at MB
How do I reset service indicator?
I have looked it up on the www but there semms to be a few ways of doing this
Anyone know thr real answer as non of them seem to work
Old Aug 31, 2011 | 06:36 PM
ronwfong's Avatar
Follow instruction on your manual on how to reset service A and B, final step is the one
that is a little confusing. Turn ignition key all the way to the right without starting the
engine, you'll see all the warning lights on..... hit reset button.
Old Sep 1, 2011 | 12:54 AM
JohnnyRaggs's Avatar
You wont find it in your manual as MB does not want just anyone to re-set it. I can't remember off hand which way it is so I will tell you both ways.
#1 - turn key to first position. cycle through your display unitll you see your odo. press reset buttong (left side of cluster) 3 times. You should hear a beep. Then press the down button on the left side of your steering wheel unitl you highlight confirm service. press lower page button (left side of steering wheel to right of down button). confirm using same button. Service interval should now be reset.
#2 - turn key to 3rd position (just before start). cycle through your display unitl you see service due time. press and hold reset button till it asks you if you want to reset service. release button and press again unitll beep is heard and service is re-set.
remember that you need to have the drivers door closed. If you mess up at anytime, removed key and try again.
Howie
Jun 11, 2006 05:17 AM
Toast
Mar 1, 2005 10:19 PM
Henry
Jan 16, 2005 11:16 PM
97420mb
Oct 13, 2004 06:45 AM
marky94301
Oct 11, 2004 07:15 PM
