Scraping noise when turn right
Old Aug 17, 2008 | 01:38 PM
bk_yxl's Avatar
Default Scraping noise when turn right
Hi, All! I have a 95 c220, recently when I make a right hand turn, I can hear a scraping noise coming from the driver's side wheel. If I brake while the right turning,there is no more noise, as soon as I release the brake, the scraping noise come back again. The noise can be heard no matter sharp or soft right turn. Could any one give me a suggestion what problem it could be? Thanks a lot!
Old Aug 25, 2008 | 03:29 AM
andry's Avatar
Default RE: Scraping noise when turn right
it could be 2 things: dirty brake pads or suspension problem (shock).
Old Aug 26, 2008 | 10:55 AM
melloc230's Avatar
Turn the left wheel until it locks out then look for signs of scraping inside the wheel well. If there is then it can be a blown strut or a bad bearing if there are no scrapes.
Old Aug 31, 2008 | 06:06 PM
Trygve's Avatar
I have a 2003 C230 and had a similair issue and it was a control arm problem.
I think it was about $400.00 CDN to repair.
FYI,
Good luck with it.
Trygve
Old Sep 18, 2008 | 12:49 AM
bk_yxl's Avatar
I have replaced the front pads and rotors, the problem isstill there. And there is a new problem, I can feel the wheel shaking every three or four seconds on speed 110kms, could it be the steering damper broken?
Old Oct 2, 2008 | 09:09 PM
ninjadojo's Avatar
change the rotor and pad. u wore the pad off now its metal to metal!! o thrown in some pad sensors too!
crit1
Sep 19, 2007 07:43 AM
rdoc
May 16, 2007 02:22 AM
cala833
Dec 3, 2006 03:30 PM
fly_major_fly
Oct 30, 2005 01:28 AM
Cedesbenz190E
Feb 7, 2004 04:48 PM
