S and W Selector Switch in C240 Automatic
Old Jun 19, 2006 | 01:10 PM
cckcheng's Avatar
Default S and W Selector Switch in C240 Automatic
What is the difference between the S and W selector switch in C240 gearbox
Old Jun 19, 2006 | 01:28 PM
gilgorm's Avatar
Default RE: S and W Selector Switch in C240 Automatic
The "S" stands for summer or sport--take your pick. Since the gearbox is driver adaptive it "remembers" your driving style and adjusts the automatic shifting to your style. In reality, it picks one of several pre-mapped shift sequences (6 or 7 programs) and uses it on an ongoing basis. If you change your style or someone else shares the driving the program will change accordingly. It won't change instantly but will "adapt" over time. It always starts in first gear.
The "W" stands for winter mode. It always starts in second gear to help in snowy / slippery conditions or lack of traction situations. It is not driver adaptive and only uses one program for all situations and all driving styles.
While I believe you can change on the fly I suggest you only change when fully stopped. It doesn't matter if you use "W" in summer or vice versa.
Old Jun 19, 2006 | 02:34 PM
cckcheng's Avatar
Thanks gilgorm
Your advice is very useful to me
Best Regards
Old Jun 21, 2006 | 03:49 AM
fly_major_fly's Avatar
Good points gil.
...the program in winter mode shifts gear up at lower rpm to minimize wheel spin.
...you can switch from S to W or, W to S as many times as you want while you are driving. the computer is not going to recognize your mood swing. no damage will be done.
***the computer reads the S or W mode only when car is in PARK***
Old Jun 22, 2006 | 03:38 PM
leonb's Avatar
ORIGINAL: fly_major_fly
Good points gil.
I drive a 1999 C280, and the S/W is accepted even when I flick the switch while driving.
Old Jun 23, 2006 | 02:14 AM
No, sir. Absolutely not.
The computer reads that S/W input ONLY while the car is in PARK.
Added later:
Only ignorant fools flip that switch while driving and believe that it works.
Old Jun 26, 2006 | 04:58 PM
leonb's Avatar
Added later:
Well, I've tried it again and it definately change the shiftpoints - even if flick it while driving. Whether its a good idea, is debateable.
So don't make a statement like "No, sir. Absolutely not", unless you're 100% sure (i.e. tried it on a late model w202)
swynn97
Jun 27, 2008 01:04 PM
peetzc
Jan 27, 2008 11:53 PM
lgmdaniel
Mercedes A Class
Jan 21, 2008 09:45 AM
winsteadi
Oct 8, 2007 05:53 PM
davnport
Jul 10, 2007 06:21 PM
