Rocker Cover Breather Hose Cracked
Whats the effect of this cracked?
Where is the transmission fluid container?
[IMG]local://upfiles/10129/1F55F236F9284070BFB78706BD59E98D.jpg[/IMG]
[IMG]local://upfiles/10129/FB1B359835C84AFE90B5241D12700D3A.jpg[/IMG]
[IMG]local://upfiles/10129/16F373811A634197B8E3C11EA2DFCB39.jpg[/IMG]
How to remove the spark plug & engine coil to check its condition?
[IMG]local://upfiles/10129/DF0783AEF7EC4922AB3536A4B6AC7F46.jpg[/IMG]
[IMG]local://upfiles/10129/FF3EAF736F444AE085BA397D850CDCFA.jpg[/IMG]
[IMG]local://upfiles/10129/6131C6A0C1054AF09BCAD0EBCB025AB7.jpg[/IMG]
ORIGINAL: rmt6668
To check the level of the automatic transmission, you need to read the dipstick. If you're car isn't equipped with a dipstick, you'll have to purchase one and follow the procedure.
Good luck!
Thanks have bought that part from MB & also check transmission fluid.
Meanwhile I'm trying to check that spark plug & coil also at same time trying to unplug the Engine Wire Harness.
Unable to reach some of the plugs?
The wires which I cannot reach according to the schematics are:-
no.65 Crankshaft Positon sender unit, camshaft position sender unit, intake
air temp sensor
no.74 intake aire temp sensor
One beside this which have no no. but look like a knock sensor?
The above is one cable harness.
Then two cables from:-
no.125 Ignition Coil
no.116 Oil Level indication
no. 89 Plug Conection Engine/Body ?
no.83 Plug Conection Engine/Body<--- I have disconnected this one?
no.101 Plug Conection Engine/Body<--- I have disconnected this one?
no.110 Plug Conection Engine/Body ?
looks ok.
air temp sensor
looks ok.
