Removing foot well panels
Old Oct 16, 2007 | 07:18 PM
Heist's Avatar
Default Removing foot well panels
I have recently had a Drive + Play installed, and theres this high pitched noise in the background that corresponds to the engines RPM. I'm told that its "alternator whine," and that a simple solution is to just move the ground from where it is to someplace else. However, the installer hid all the cables for aesthetics, and i need to remove some of the foot well (passenger side) panels so that i can try to follow the ground and move it. can anyone tell me how to do this, or even better, does anyone have pictures of this? thanks
Old Oct 16, 2007 | 07:21 PM
Heist's Avatar
Default RE: Removing foot well panels
anything will help
Old Oct 17, 2007 | 09:55 AM
mrcoyote's Avatar
You're right.....high pitched whine noises in audio that follow engine rpm are usually alternator noises.
Did you take it back to the installer and tell them about it? That's what I would do first if possible. They have
the responsibility of making it right for you. They should be happy to do something as easy as move the ground.
Also, they have "filters" that can be put in the line to cut down on this noise or eliminate it. They must do this
all the time if they install. They are pretty easy to put in and fairly cheap. Just big condensers I think. But I would
let them try first at no expense to you. Or at least it shouldn't be.
Old Oct 17, 2007 | 10:24 AM
Heist's Avatar
i agree. that would be the first thing i'd do also. However, i had it done near New York City and i'm at school in upstate new york, so unfortunately thats not really one of my options. I called mercedes and one of the guys at the nearest dealership (near Syracuse) said that we'd play it by ear, but he might be able to help me out and at the very least show me how to remove the paneling. But if at all possible i want to avoid the drive not to mention the possibility of 50 dollars of labor an hour. thanks
Fingerz
Dec 5, 2008 06:31 PM
flyfishingbear
Aug 24, 2006 12:57 PM
Uneek
Aug 31, 2005 08:00 AM
C280 wizard
Aug 23, 2005 12:50 AM
C280
May 19, 2005 09:32 PM
