RADIO PROBLEMS
RADIO PROBLEMS
GREETINGS ALL,
The radio in my 98 c280 powers on, tunes seeks etc. but no audio is heard. I have the Bose marked system.
Fuse blown?? If so what position ? The fuse panel sheet is a bit smuged, and the old eyes aren't what they used
to be.
Thanks in advance
to be.
Thanks in advance
RE: RADIO PROBLEMS
I'd check the fuse in the amp. which on my 99 C280 is located in the trunk on the left side (driver's) under the covering. Most amps have separate fuses to protect the circuit to the speakers etc. That is if you have a Bose system. On the system the car is equipped with unless you check Bose onthe option sheet the radio powers the speakers, it also may have a fuse on the speaker circuit?
pags
11-07-2007 11:52 PM
smokymcgee
03-18-2006 01:15 AM
