radio not working c300
my radio is not working,, no sound ,,,all lights and display are on ,,,,when trying to adjust balance fade or such,, all are showing 0 and when adjusting volume nothing changes on display as if the volume button isn't working fuses checked both of them
We are experiencing similar issues with our 2012 C300 radio... all the lights are on, but nobody is home - No volume. The system responds to voice commands, and functions properly in all radio/audio modes. All displays function normally. We just can't hear it.
When this happened (in another city - 150 miles from our dealer), we pulled into a MB dealership just as the service dept. was closing (naturally). After a minute or two of fiddling with it, the service tech told us he thinks ours is a problem he has seen before - probably a bug in the software.
I'll advise if I learn more.
Good luck!
Good luck!
Word from the dealership is that the whole unit will have to be replaced. The software "fix" did not work.
By the time it is fixed, we will have been without a radio for two weeks, and I will have about six hours of seat time in the dealership...
The car has a whopping 4K miles. Needless to say, we are not impressed.
My 2013 C300 has about 5K miles on it and the radio/screen does not turn off occasionally (even without the key in the ignition and locked the car). Does anyone else have similar problems? I have taken to the mercedes dealiership twice and they told me it's not fixable and I should only use apple products for bluetooth, no androids (that's a stupid suggestion).
My Radio was working but all lights and display are not working and all the buttons on the radio no response and can't turn off the radio with the Power Button. To change stations I had to use control **** or the dial. So everything works from the Dial ****. Why ????
Thanks for reply. I didn't do a diagnostic on my car and there is no code pop up on the screen to check it either . I'd check all fuses they are all good. And I disconnected the battery also. It was strange that I could play the Cd but then I can't eject it out . I will take it to Mercedes dealer to have it check someday .
