problem with my 2000...it doesn't switch gears!! help?
Old Aug 8, 2007 | 09:07 PM
Alarcon0515's Avatar
Default problem with my 2000...it doesn't switch gears!! help?
it happened 6 months ago and stopped using it since...now I want to fix the problem.... specific suggestions anyone??
when I turn it on, the dash doesn't even tell Me it's on P ( parking ) anymore... It drives...but only on 1 gear.... repair shop suggeseted new shifting device for $550 plus $200 installation...is that about right??
money saving suggestions appreciated.
Old Aug 14, 2007 | 12:53 AM
MBTECHINFO's Avatar
Default RE: problem with my 2000...it doesn't switch gears!! help?
High probability that the Shifter (ESM) is the problem. Also, check the front passenger footwell under the carpet and under metal plate with 3 plastic 10mm nuts for the transmission control unit. These are prone to oil contamination. Oil creeps up the trans wire harness inside the wiring and floods the computer. Common problem
gadget153
Jan 24, 2009 07:53 AM
hughits
May 19, 2008 12:26 PM
robins13
Oct 2, 2007 06:43 PM
Alarcon0515
Aug 8, 2007 08:35 PM
CCCP
Feb 18, 2005 05:10 PM
