pls pls pls pls help
Old Feb 14, 2008 | 04:08 PM
Supercharged macca's Avatar
Default pls pls pls pls help
hi i have a N-reg C230K (manual) and when i floor it it sounds like its flooding or not firing properly it just borkes and goes slugish.
also on tickover it doesnt tickover properly it nearly stalls or does stall.
i found a sensor or what looks like a sensor wich was hanging down on wireing under bonnet its the 1 that clips into the plastic intake wich joins onto the inlet manifold.
what could be wrong with the car? cheers macca[/align]
Old Feb 15, 2008 | 09:10 PM
Shan's Avatar
Default RE: pls pls pls pls help
Are you sure it is a sensor and not just a connecting plug (plastic casing with pins inside)?
It looks like the connection to the MAF has come loose.
Fix it to the socket at the MAF casing carefully and get back to us.
Shan.
thomasebud
Feb 15, 2010 10:02 AM
Janet K
Jan 22, 2006 07:19 AM
arm0rallday
Sep 25, 2005 12:41 AM
neportlandmv
Jun 11, 2005 11:18 PM
sppcartons
Jun 8, 2005 02:51 AM
