P0170 code
Old Jan 9, 2004 | 02:23 AM
  #11
ahasanat's Avatar
Default P0170 code
Dale thank you very much for your help</P>
I have code P0170 with check engine light, I reset it with no luck.
Injector Leak or Vacuum leak or Pressure regulator.
I am not a mechanic, I will have a mechanic work on the car.
1- I would like to know how to test for Injector Leak and how much time require.
2- test for vacuum leak, how much time is required, what value is good. what happened if they found a vacuum leak.
3- how to test for pressure regulator, what to look for.
4- how to test the MAF and O2.
5- anybody had problem with gas cap.
6- dealer do not recommended Techron, did any body use with no problem.
7- disconnecting the battery would cause any problem with this car.</P>
chanto
Oct 4, 2006 08:00 PM
joaohf
Aug 6, 2006 04:38 PM
contractsguy
Jul 7, 2006 03:51 AM
snowpups
Dec 15, 2005 04:11 AM
snowpups
Oct 25, 2005 11:40 PM
