Newbie with anti-theft question
Old Feb 22, 2006 | 10:05 PM
arkansascarnut's Avatar
Default Newbie with anti-theft question
Hello all, just purchased a '95 C280 - beautiful one owner, very clean, etc. The previous owner had an aftermarket keyless entry installed. I removed the universal keyless because I wanted to utilize the window up/down feature with the key in the door. Now my question: According to my owner's manual, I should have a red LED blinking on the rear headrest release button when locking the car with the key (simultaneously arming the alarm). The LED doesn't flash. I've checked the fuse in the trunk as well as under the hood (the ones labeled anti-theft). Anything else I could check? BTW, the universal keyless was just that - no starter kill, no siren under the hood, etc. It was just a ground, two power wires and 2 wires spliced into the driver's door wiring.
Thanks for any input! I've already learned a lot about my car by searching the forum.
Old Feb 24, 2006 | 12:05 AM
fly_major_fly's Avatar
Default RE: Newbie with anti-theft question
There had to be a reason why the previous owner put a third-party keyless entry system. There is something fishy about it. Why would he install that if the OEM key fob remote was working flawlessly? Right?
Old Feb 24, 2006 | 12:18 AM
Lugnut's Avatar
To switch from IR to RF, maybe? Or, as I suppose you suspect, the factory one was broken?
Old Feb 24, 2006 | 04:39 PM
Hm..hadn't thought of that one. I guess I'll make a visit to the dealership to check on OEM equipment that came on it. I'm assuming all Benz' come standard w/ keyless?
Sorry...still learning about MB's. I can answer questions all day long about 3 Series and Miatas though
Old Feb 24, 2006 | 08:05 PM
ORIGINAL: arkansascarnut
Are you sure? I have not seen a 95 with LED on the rear headrest release button. The security LED is on Tow Switch, unless you have a Nieman-Marcus Mercedes Benz. (Or, perhaps I am drunk.)
No Benz comes with standard keyless entry system, technically. The security remote that comes with a Benz has a mechanical legacy key in it, so you cannot dub it "keyless".
Old Feb 27, 2006 | 04:13 PM
Sorry for the typo. My owner's manual actually states that the flashing led is located in the door lock/unlock button on the dash, not the headrest button as I stated. Going to the dealership today to find out exactly what was equipped on my car. It's not a N/M edition btw.
cobbcfi
Aug 6, 2010 05:59 PM
MBENZ300SD
Jun 9, 2008 09:29 PM
Eatincake
Mar 18, 2007 12:35 PM
rtrimarchi
Apr 24, 2006 06:59 PM
buckeye560
Apr 5, 2005 08:46 PM
