need radio replacement help
Old Dec 28, 2007 | 06:20 PM
jakeesspoo's Avatar
Default need radio replacement help
I have a 94 c280 I took out my becker head unit and put in a pioneer. I hooked up all the speaker wires and power to new head unit but I get no sound?[X(] I figured out what wires were what by using a guy named k6jrf's web site. Is there a amp or something blocking the output to speakers. Anyone who has replaced there factory head unit themself your comments would be greatly appreciated...
Old Aug 23, 2008 | 10:10 AM
Chadted's Avatar
Default RE: need radio replacement help
yes there is a factory amp in the trunk on the left side. you need to go through the amp to get sound. Using any preamp outputs would be ideal, and if you dont, dont turn up the new head unit too loud or you could fry your speakers. I just did the same thing on my '94 C280 and am persuing bybassing the amp.
Old Aug 26, 2008 | 10:52 AM
melloc230's Avatar
This is the problem with factory pre-amp'd systems. They are a pain to deal with especially trying to mate them with aftermarket head units. It would have been ldeal to look for a wire harness adaptor kit. THis would have eliminated cutting but if they do not make an application for your year then it would be easier to bypass all together. The aftermarket unit will not have enough power to run the speakers by itself so get yourself a good 4-5 channel amp that will power the entire system.
zdzich
Aug 21, 2012 12:53 PM
BradFri
Apr 27, 2012 11:39 PM
silentwatchdog00
Apr 15, 2008 01:30 AM
Scythe
Mar 5, 2008 11:30 AM
87300eamg
Oct 12, 2005 09:37 AM
