need help finding out what is compatible with a 96 C 280
I have a 96 C 280 and the wiring harness for the engine has burnt up. I have 2 questions, 1 is this a common problem, & 2 , what years are compatible with this 96? I found a 98 in the junk yard that I can get the harness of off but I don't know if it'll work. also it seems like maybe the burning up originated from the spark plug coil pack wires. thanks for any help
You will have to check by your VIN# and part # on the harness. There were several different versions. The part # on the harness is by the main ECU connector. It's a white tag. I recently rebuilt the wiring harness on my 95. When I was checking around, it appears you have to be very careful on which harness you get since there were minor differences made throughout.
xjvoorheesx
07-29-2006 12:51 AM
300d adic
02-04-2006 02:08 AM
