Lowering a 96 C200
Old Jul 9, 2006 | 04:23 AM
crazyjester900's Avatar
Default Lowering a 96 C200
hi guys, i have recently fitted MAGS to my car which i really like, the next step is lowering the car. I just have a few questions
- The difference between
* Getting new springs installed to lower the car
* Changing the whole suspension setup to lower the car
Also i want to buy my own springs and take them to the place to lower the car that way i only pay labour, can anyone help me in finding the right springs for my car??
Thanks guys for your assistance its helped alot
Cheers Brad
Old Jul 9, 2006 | 05:42 PM
drblank's Avatar
Default RE: Lowering a 96 C200
First question is why do you want to lower the car?
Second, get Eibach sway bars. THEY ROCK and will improve your handling GREATLY. I would do that first.
Next, I would consider new shocks if the one's you have a lot of miles on them I recommend Koni adjustable....
Springs you have to make sure you get shims. They have 5 different thicknesses for the front and 4 for the back. If the car gets lowered, it will affect the camber and will probably make the rear camber offset 2 or more degrees off. This will result in nice handling, but increase in inner tire wear.
I am not sure about your suspension, but you probably don't have an adjustment for camber. Also, check your tie rod assembly, you might have to replace it as well as lower control arm bushings.
First make sure the rest of your suspension is in tip top condition first.
Replacing sway bars is the best thing you could ever do.
Old Jul 10, 2006 | 01:37 PM
K1MOTORSPORT's Avatar
Yes, Eibach springs are good and we do have them for your vehicle.
Old Jul 10, 2006 | 05:30 PM
sacc230's Avatar
or the H&R springs I think they lower your car more than the ebiachs do
Old Jul 10, 2006 | 05:49 PM
Eibach lowers 1.2" all around and H&R lowers 1.4" front and 1.3" rear.
Old Jul 11, 2006 | 01:05 PM
Hey thanks for your help,
I basically wanna lower my car for looks and a bit of handling,
I didn't know that, that manny parts had to be changed to lower the car i knew the shocks and the springs.
The sway bar what roll does that play in lowerd the car??
Cheers for your help.
Brad
Old Jul 11, 2006 | 01:07 PM
K1, i Live in Australia,
What are the prices for these parts for the car??
and where are you?
i appriciate the help you all have given
cheers Brad
Old Jul 11, 2006 | 01:13 PM
1996 Mercedes W202
i can't get the picture thing to work so here is a picture of my car.
in terms of suspention my car is 100% stock..
The wheels on the car are 17"
http://viewmorepics.myspace.com/inde...7-991380cb6fc6
Cheers brad
Year1998C200
Jul 15, 2007 04:34 AM
krypto
Apr 1, 2005 09:03 PM
abroom
Oct 27, 2004 08:22 AM
John Johns
Dec 29, 2003 06:56 PM
