k&n air filter
Old Jan 13, 2008 | 08:46 PM
odessit's Avatar
Default k&n air filter
before installing k&n air filter into 2007 c230 sport do you need to dry it from the oil?
how many filters does the 2007 c230 need?
thanks
Old Jan 13, 2008 | 09:14 PM
C280 SPORT's Avatar
Default RE: k&n air filter
Mine was takin out if the box and installed in less then 5 min.
Old Jan 13, 2008 | 10:42 PM
mrcoyote's Avatar
"Dry it from the oil"???
I'm not even sure what that means, but..........
K&N air filters come pre-oiled from the factory and ready to install as they are.
You will see the pleats of the filter with a red oil already on them. Leave the filter as is and install.
There is a specific procedure you do when you go to clean them, which, honestly, isn't all that frequent.
BUT, when you do, or IF you do, get the K&N filter cleaner in a bottle and follow instructions carefully.
Then use the K&N oil in a small spray can and again, follow instructions carefully. If you don't, you will only
screw up not only the filter, but maybe more. Enough said.
If you need help with any of this, repost and I'll fill you in.
StickyBenz
Feb 1, 2012 06:24 PM
dablk1
Mar 30, 2009 04:10 PM
parasuco
Mar 13, 2009 02:21 PM
Lhaitzss
Mar 5, 2007 10:44 PM
BlueML320
Oct 22, 2006 04:02 AM
