Fuel Trim Malfunction
Old Nov 9, 2010 | 03:24 PM
Josh L's Avatar
Default Fuel Trim Malfunction
I have a 99 c230 kompressor and I have a check engine light on showing a p0170 (Fuel trim malfunction). I have replace the Fuel Pump, Fuel Filter, Fuel regulator, Spark Plugs, and had it check for Vacuume Leak.. It seems that none of these have fixed the problem... Was wanting to know if an o2 sensor would cause this code to come up... Dose anybody have any Ideas...
Old Nov 10, 2010 | 09:49 AM
platonmind's Avatar
Usual suspect is upper stream 02 sensor. In my case it was.
Old Nov 10, 2010 | 10:01 AM
Josh L's Avatar
Thanks for your info.. I will try that out and post the final result...
Old Nov 15, 2010 | 04:31 PM
Josh L's Avatar
Replaced the front o2 sensor and it fixed the problem... Thanks
paul0120
May 30, 2008 10:10 PM
harryco
Jan 10, 2008 12:34 AM
webberkyle
Oct 16, 2007 09:53 PM
webberkyle
Oct 15, 2007 11:58 AM
benzowner
Jun 5, 2007 11:52 AM
